09-05-2018 07:36 AM
in the installation manual for the Cisco Spark Kit Plus there indicates an audio line input on the quad camera. Does any know the behavior of this input? is this a simple input to make use of the soundbar?
thanks!
09-05-2018 10:18 AM
Yep! Line out from the codec goes to line in on the quad cam/soundbar if you are going to use is for that purpose.
11-26-2019 07:44 AM
11-26-2019 08:17 AM
It's line out/in. The amplifier is in the quad cam unit if you use those speakers.
11-26-2019 08:35 AM
04-25-2021 02:25 PM - edited 05-11-2021 02:06 PM
The widespread room it isn't definitely intended for a twin digicam setup. It does have an HDMI input link, meant for pc display screen sharing, and you can in idea plug in a Go Pro (I actually have finished this) however its no longer in reality designed for that.
