Hi smart people :)
So, one of our VPs would like to have a personal VC in his room. He wants to have a 60" TV on a tiltable arm... So I will install a SX10 under the TV. However, he doesn't want the audio to come out of the TV speakers or any attached speakers, he wants the audio to come out of the table..... yes.... table.
When I told him we can install a 360 degree speaker (http://www.samsung.com/us/experience/radiant360/) and Cisco mic next to it he refused... he said he wants something like the Jabra SPEAK 510, which he's using while traveling to join conference calls.
So my question to you is..... is the Jabra SPEAK 510 going to work with the cisco SX10? I know the T10 has 3.5mm port, and two USB ports, can I use that? If not, I will use an audio converter to pair the speaker and mic inputs into one, and connect the Jabra SPEAK 510 into it.
He doesn't want to spend a lot of money on it, but he wants this solution, where he has only the puck on the table... the T10 will live on a wall behind him.
BTW I know the Jabra is compatible with Cisco, for instance EX90, but no word about the SPEAK 510....
COMPATIBILITY_OVERVIEW_PDF.pdf
Thank you
