06-23-2015 08:25 AM - edited 03-18-2019 04:38 AM
Hi everbody,
We have been using C90 codec and TC console and can easily set up a conference with multiple monitors:
1st monitor: main camera
2nd monitor: presentation,
3rd monitor : remote camera.
SX80 have also 3 monitor outputs. Can we set up the same configuration with sx80 .
Is there anyone using 3 monitors setup with sx80 ?
06-23-2015 11:28 AM
The SX80 has a built in functionality where what you want is part of the software, see the SX80 Admin Guide, starting on pg 136. One of those scenarios might work for you out of the box, or you could use TC Console to manipulate the layouts as you're doing with the C90.
06-23-2015 05:38 PM
Thank you Patrick.
We will try with TC Console.
