Cisco SX80 removing 'No camera connected' warning from OSD
uscourtswvnd04
Hello.
How do I remove the 'No camera connected' warning message from the on screen display?
I am using input 4 and I don't need the camera.
Thanks again!
18 Replies 18
I agree - this solution worked for me in version ce9.7.8
Would also like to add that this is the correct answer to this problem, with no extra screen workaround required!
You can't, only the original poster can choose the correct answer. This thread is three years old, the answer then was the correct answer then.
That did it !
Thank you.
Log in to the codec.
(you need the IP address, username / password)
Go to:
Setup > Configuration > Peripherals > (in the “Profile” area, set “Cameras” to 0.
Press “Save” on the top right of the screen.
Message went away.
