07-09-2019 02:09 AM - edited 07-09-2019 02:10 AM
Goog day.
To integrate Cisco SX80 (TP) with AMX, we need a driver not lower than Cisco_SX80_v1_0_4_dr1_0_0. Can you help him find it?
Best Regards,
Vyacheslav
07-09-2019 06:38 AM
That's an AMX file/driver, you won't get it from Cisco. I'd suggest starting here, if you can't find it they have a "contact us" page you can use to ask how to get the driver.
07-15-2019 08:45 PM
You will find that that particular module is really old and only supports the old TC software. You will be much better off using a newer one that supports the newer CE software loads.
If you're a registered AMX developer, head over to https://trade.amx.com/Net/Inconcert/Devices/InConcertMainPage.aspx and have a look there, otherwise, just research the API guide and send your own commands as required.
Please remember to mark helpful responses and to set your question as answered if appropriate.
