Cisco_SX80_v1_0_4_dr1_0_0 Driver for AMX
sun_sazanov
Goog day.
To integrate Cisco SX80 (TP) with AMX, we need a driver not lower than Cisco_SX80_v1_0_4_dr1_0_0. Can you help him find it?
Best Regards,
Vyacheslav
PJMack
Level 7
Level 7
That's an AMX file/driver, you won't get it from Cisco. I'd suggest starting here, if you can't find it they have a "contact us" page you can use to ask how to get the driver.
https://www.amx.com/en-US
Wayne DeNardi
You will find that that particular module is really old and only supports the old TC software.  You will be much better off using a newer one that supports the newer CE software loads.
If you're a registered AMX developer, head over to https://trade.amx.com/Net/Inconcert/Devices/InConcertMainPage.aspx and have a look there, otherwise, just research the API guide and send your own commands as required.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
