Cisco TelePresence C-series API: Shutdown command
Rejohn Cuares
Level 4
Level 4
Hi All,
I'm looking for an API command that shutdown the codec. I've checked the C-series API TC4 and TC5 for the said command but I wasn't able to find it.
Has anyone knows the command to shutdown the codec?
Thanks!
Please rate replies and mark question as "answered" if applicable.
vivsing2
To shutdown device i found one command on TC5.1, not checked on TC4
xcommand Boot Action:Shutdown
You can try this command to shutdown device.
Vivek
vivsing2
Vivek
If you have root access you could also try the "shutdown -h now" command, but for example my E20 still just reboots
(it also does not have a powerbutton or WOL so it might be hard to turn it on again :-)
So I could picture its also dependent on the endpoint, the EX series has at least a power button.
Vivek: as the release notes of TC5.1 state that this is a new api command I would not expect it not to work in older releases.:
http://www.cisco.com/en/US/docs/telepresence/endpoint/software/tc5/release_notes/tc_software_release_notes_tc5.pdf
Changed API commands
xCommand Boot
• Added: Action:
