12-19-2014 02:21 AM - edited 03-18-2019 03:49 AM
Dear Community,
In order to activate AES encryption, how to get the Key?
kind regards
12-21-2014 05:01 PM
As long as you are not in an restricted country, your Cisco Partner should be able to place a
0 dollar item order for it.
Before you do that you, your partner or cisco licensing if the key is already present
in the licensing portal.
http://www.cisco.com/web/go/license
sometimes it was ordered but simply never added
12-28-2014 07:12 PM
As Martin said above, check the licencing portal and see if you already have a key for your device:
If you can't find it there (which we couldn't recently for one of ours), you need to contact your local reseller or Cisco account rep and they can place an order for one. Again, as Martin has indicated, it was a zero cost key when we asked for it, but can take a few weeks for the orders to progress through the system.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
