09-16-2020 02:57 AM
Is there a good document which explains the custom wallpapper for cisco telepresence?
I have read that when you use a custom wallpaper, these items are removed from the main display: • The large clock • The list of upcoming meetings.
My question is how does the custom wallpapper affect it with makros and scripts?
What do we need to think of when using custom wallpappers?
Solved! Go to Solution.
10-28-2020 08:49 PM
The custom wallpaper does not impact macros and scripts, they are still able to be used.
Setting a custom wallpaper disables the background image in all screen states, and disables the "One Button to Push" functionality, meeting info, and default usage prompt.
The "custom wallpaper" can be seen as a legacy feature. It is recommended that you consider using the "Branding" feature to get a better and more consistent user experience.
See the latest Admin Guide for the model of endpoint you are using for more detail.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-28-2020 08:49 PM
