Cisco Webex room kit/mini
adamgibs7
Level 6
Level 6
Dears
I can see in the datasheet only webex room kit mini and webex room usb are the only 2 devices can connect to laptop and can be used a camera/audio/mic to any client.
Also i would like to confirm the webex kit and kit plus can work as usb connection for sharing of video camera, mic, speakers
2 Accepted Solutions
zeuscyril
Level 4
Level 4
not possible those are codecs you cant use as usb input in PC or Laptop.
The only way this is semi-possible is if you use one of the spare HDMI outputs (if you have any) and send that in to a HDMI->USB converter attached to your laptop.   If you need the audio as well, then there are some more hacks that introduce more hardware to do that.   It's not an out of the box capability, but it can be done.
If you want it to work out of the box, then the Room Kit Mini/USB are the only endpoints that this works on currently.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
adamgibs7
Level 6
Level 6
Dears
anybody can put some shade for the above query.
Wayne
zeuscyril
Level 4
Level 4
