Cisco Telepresence MX700 weights + dims
adam.urb1
Good afternoon,
I'm in the early stages of planning the installation of one of these units and it would be very useful to know;
a) The weight and dimensions of the packaged unit as a whole.
b) The weights and dimensions of the main individually packaged components (i.e. screens and base - boxes A and 2 x D) as can be seen in the Cisco floor stand installation guide document, page 3.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/mx-series/installation_guide/mx700-dualcam-floorstand-installation-sheet.pdf?mdfid=286248449
The weights and dimensions given in the document seem to be those of the assembled unit and do not include any packaging weight etc.
This is all to allow me to work out the logistics of getting what is a fairly large consigment to a third floor office location - I need to know if the whole unit will fit into the available lift at site, or whether it will be necessary to break the main package down into the key parts as they are packaged individually, in the hope that these may fit into the lift.
Is anybody able to offer this information, please?
Many thanks
Adam.
Hendrik Schraa
Hi Adam,
Page 127 of the MX700/MX800 administrator guide should clarify this for you.
Packaging dimensions and weight:
MX700:
• H: 62.20” in. (158.0 cm)
• D: 30.51” in. (77.5 cm)
• W: 61.69” in. (156.7 cm)
• Weight w/Single Camera: 498.2 lbs (226 kg)
• Weight w/Dual Camera: 511.5 lbs (232 kg)
Product dimensions and weight:
MX700:
• Width: 99.09” in. (251.7 cm)
• Height Freestand: 64.33” in (163.4 cm)
• Height Wallmount: 42.17” in (107.1 cm)
• Depth Freestand: 4.76” in, 36.22” incl. feet (12.1 cm,
92.0 cm incl. feet)
• Depth Wallmount: 5.83” in (14.8 cm)
• Weight Single Camera: Freestand: 339.51 lbs
(154.0 kg)
• Weight Dual Camera: Freestand: 352.73 lbs
(160.0 kg)
• Weight Single Camera: Wallmount: 357.15 lbs
(162.0 kg)
• Weight Dual Camera: Wallmount: 370.38 lbs
(168.0 kg)
Hendrik Schraa
Hi Adam,
MX700:
MX700:
92.0 cm incl. feet)
(154.0 kg)
(160.0 kg)
(162.0 kg)
(168.0 kg)
That is excellent, many thanks for your response, Hendrik, very much appreciated!
