Cisco Telepresence Table Microphone 20
jason_tan
Hi Guys,
I would like to check what is the limitation of the cable distance for Table Microphone 20?
I will be using with Cisco SX20 codec.
Is there any extension cable to extend the microphone cable? If there is, any part number reference?
The distance I'm looking at is around 10 metres here.
Can anyone help?
Patrick Sparkman
Hello Jason -
The cable that comes with the TelePresence Precision Microphone 20 is 7.4 meters.  There is an extension that will give you an additional 10 meters, it's CAB-MIC20-EXT=.
c20-microphone-extension-cable-max-lenght
SX20 Mic cable Length
Patrick Sparkman
Hello Jason -
