Cisco Touch for CTS Systems
Henning Haendel
Is it right, that I need at least CUCM Version 8.6 to use the touchpanels as remote control for the CTS Systems?
Sent from Cisco Technical Support Android App
Marius Nedregaard
Hi.
I quote
"CTT 12 is not supported on any releases prior to 1.8.0. Systems that are running Cisco TelePresence System software releases 1.8.0 and above must use a COP file to upgrade and install their software."
http://www.cisco.com/en/US/docs/telepresence/peripherals/cisco_touch/installation/cisco_touch_installation_understanding_cop_files.html
If i point you to this link
http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_8/compatibility/cts_compatibility_master.html
And from the installation guide i see this:
The Touch device requires a minimum Unified CM version of 8.5.1.
So, you do not need CUCM 8.6 but you need at least 8.5.1
//Marius
Marius Nedregaard
Hi.
I quote
//Marius
Henning Haendel
Cool, thanks a lot!
