10-02-2018 10:53 AM
I am working in Cisco Unity Version 11.5.1.14900-11
I have worked with a counterpart to this product, CUCM, in the past, but this is my first experience with CUCA.
I am curious to know if there is a module within the standard CUCA 'directory' (looks more like a table of contents starting with the Users node) that will allow me to view the MAC address of the phone associated with a user extension.
I recall being able to find this information quite easily when using CUCM, previously, but for all of my looking I cannot find it in CUCA.
Is it there?
-Chris
Solved! Go to Solution.
10-02-2018 11:04 AM
CUCA assigns voicemail boxes by extension. You will want to use CUCM to gain information about the devices the extensions are assigned to.
10-02-2018 11:23 AM
CUC has no visibility of such information, in reality, it doesn't even care what kind of device you use to reach/use CUC as long as the CUCM/CUC integration is properly configured.
All the info you want, is in CUCM.
10-02-2018 11:04 AM
10-02-2018 11:23 AM
