cisco vcs Interworking No permission
Call details on the VCS-E :
marnove02 - Call details
Bandwidth node Default zone
Source alias 1 HDX_Systeam (H323Id)
Source alias 2 54271 (E164)
Target alias 1 74002 (E164)
Protocol H323
Address IP
Encryption type None
Reason No permission
Cause Interworked
Additional cause Insufficient privilege
It's due to an inbound call from an endpoint behing Polycom infras.
How do you interpret the "reason" ?
Firdaush
Is this correct Neither endpoint is registered to your VCS-C or VCS-E?
6 Replies 6
Patrick Sparkman
Where is the other endpoint located, is it registered to your VCS-C or VCS-E?
I've seen some instances where interworking will fail if the call is going through the VCS-E and it's set to interwork registered endpoints only, which is the default setting.  What happens if you set interworking on the VCS-E under Configuration > Protocols > Interworking, to on instead of registered only?
There is no endpoint registration neither on the VCS-C nor the VCS-E.
The interworking is alreaty set ON.
Lawrence James
Can the near end (NE) system call the far end Polycom (FE) by Alias?
Can they call  each other by IP?
What happens in each case?
Have you looked at your Traversal Zone? Did your VCS Control even see the call?
Hello Lawrence,
Reply: Call is made through TMS by calling IP@domain.com
Reply: NO
The VCS see the call.
487 Request terminated
