01-07-2016 06:19 AM - edited 03-18-2019 05:23 AM
Call details on the VCS-E :
marnove02 - Call details
Bandwidth node | Default zone |
Source alias 1 | HDX_Systeam (H323Id) |
Source alias 2 | 54271 (E164) |
Target alias 1 | 74002 (E164) |
Protocol | H323 |
Address | IP |
Encryption type | None |
Reason | No permission |
Cause | Interworked |
Additional cause | Insufficient privilege |
It's due to an inbound call from an endpoint behing Polycom infras.
How do you interpret the "reason" ?
Firdaush
Solved! Go to Solution.
01-07-2016 11:10 AM
Is this correct Neither endpoint is registered to your VCS-C or VCS-E?
01-07-2016 06:50 AM
Where is the other endpoint located, is it registered to your VCS-C or VCS-E?
I've seen some instances where interworking will fail if the call is going through the VCS-E and it's set to interwork registered endpoints only, which is the default setting. What happens if you set interworking on the VCS-E under Configuration > Protocols > Interworking, to on instead of registered only?
01-07-2016 07:47 AM
There is no endpoint registration neither on the VCS-C nor the VCS-E.
The interworking is alreaty set ON.
01-07-2016 11:10 AM
01-08-2016 04:06 AM
YES
01-07-2016 11:08 AM
Can the near end (NE) system call the far end Polycom (FE) by Alias?
Can they call each other by IP?
What happens in each case?
Have you looked at your Traversal Zone? Did your VCS Control even see the call?
01-08-2016 04:03 AM
Hello Lawrence,
Reply: Call is made through TMS by calling IP@domain.com
Reply: NO
The VCS see the call.
487 Request terminated
