04-16-2013 03:29 PM - edited 03-18-2019 12:57 AM
VCS is returning a search error No shared media codecs when trying to establish a call to a Cisco 4500 Series MCU.
Has anyone come across this issue yet ? The codec is c20 on TC6.1
04-16-2013 05:33 PM
Hi. Can you list the versions for MCU and VCS? Do you notice this on SIP to SIP calls? Interworking calls? Some more detail would be helpful to see what scenario it happens in . Let us know?
VR
Patrick
Sent from Cisco Technical Support Android App
04-21-2013 10:48 PM
Hello Patrick,
VCS version is X7.2, call is SIP to SIP, MCU as a neighbor zone on the VCS, MCU version 4.4(3.42)
Deregistering and reregistering the codec on the VCS solved the issue, but I am wondering about the root cause here.
04-17-2013 02:48 PM
If I see it right TC6.1 is not released, so if its an beta ask your beta team,
if its not an EFT downgrade to a release version like TC6.0.1.
Check if there are any limits set on the codec selection. Starting with
a factory reset device might help as well.
Besides that, like Patrick also said, without more info there is not much to say,...
04-23-2013 04:55 AM
HI. Its going to be hard to determine the reason why to be honest without looking at a log from MCU or VCS to see what the MCU didn't like or what was missing in SDP to/from MCU. If your able to reproduce or the problem creeps up again, running H323/SIP log on MCU and pulling the event log from MCU would help. Coupled with network log debug from VCS side as well.
Will keep trying in the lab to see if any combo's produce this. But if you run into it again, would be nice to grab those logs if possible.
VR
Patrick
04-23-2013 06:54 AM
Hi Patrick. I completely agree with you, it was just I really could not afford the time to do log collection and tshooting as this is a production environment. If the issue reappears I will try to isolate and get the logs.
My inital thought was that you possibly already had a TAC case on this, and you already roughly know where the problem is.
Thanks.
