Cisco Webex CP-DX80
ahmaddhaher
Does the Cisco Webex CP-DX80 support external wired microphone/speaker via one of its USB connections ? If yes , is there a specific compatible model or any generic type will work ? Thank you.
If it helps you find something compatible, there's a list of USB Headsets and Handsets Supported for DX80.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
PJMack
Level 7
Level 7
I personally have used a Jabra Speak USB speaker/mic unit, so I know they will work. Cisco and Jabra do a lot of cross testing, so they are a safe brand I think.
Wayne
Thank you so much.
