CMM feature suggestion - display mediaProcessingLoad values for each CMS server
bvanbenschoten
Level 5
Level 5
AFAIK, the mediaProcessingLoad value can only be access via the API.
If we could bring this into CMM that would be great.  Display per server
Stretch goal, whenever a manual threshold  or the newConferenceLoadLimitBasisPoints limit is reached, send an email or log event
Its difficult to manage capacity on the CMS currently.
https://{{_cmshost2}}:445/api/v1/system/load
<?xml version="1.0"?>
<load>
    <mediaProcessingLoad>0</mediaProcessingLoad>   <== Start with this.  Could you graph it over time ?
</load>
<cluster>
    <uniqueName>cb01</uniqueName>
    <maxPeerVideoStreams></maxPeerVideoStreams>
    <participantLimit></participantLimit>
    <loadLimit>96000</loadLimit>
    <newConferenceLoadLimitBasisPoints>5000</newConferenceLoadLimitBasisPoints>
    <existingConferenceLoadLimitBasisPoints>8000</existingConferenceLoadLimitBasisPoints>
</cluster>
Jaime Valencia
Submit a PER via your SE/AM for this.
java
if this helps, please rate
Jonathan Schulenberg
V!
Did you mean to post this in the CCP feature request or partner spaces? You know PMs don’t read CSC threads. :)
