10-27-2020 01:54 PM
Has anyone got Cisco Meeting Server (CMS version 3.0) working with live streaming (RTMP) without support of other components (like vBrick, WOWZA) ??
From CMS 3.0 release notes, it seems capable of providing a RTMP stream for outside (e.g. sending live stream to "rtmp://mystream.com/live/app"). However there are no documentation or validation that CMS alone can achieve live streaming into youtube or facebook.
Any ideas ? Thanks in advanced.
Solved! Go to Solution.
10-27-2020 11:33 PM - edited 10-27-2020 11:34 PM
You need Vbrik or Wowza.
Have a look on Deployment Guide.
10-28-2020 04:57 AM
I have done Youtube using WOWZA and its pretty straight forward. you get 30 days demo license and u can make it from their website.
10-28-2020 02:39 AM
Thanks @Nithin Eluvathingal. We tested this out with vBrick DME server. Our main concern was to stream CMS RTMP feed into facebook live. Since facebook does not support RTMP anymore (facebook supports RTMPS only now), we had to use OBS Studio to collect RTMP stream from vBrick DME, and then use facebook stream key and post it live. vBrick current do not direct facebook live streaming it seems.
10-28-2020 03:08 AM
What about Wowza have u tried it ?
10-28-2020 03:22 AM
I also noticed that Wowza offering rtmps facebook streaming and youtube live. I requested a demo from them, once it’s available I’ll check that and let you know how it goes.
Thank you !
10-28-2020 04:57 AM
12-20-2020 12:01 PM
Hi Team
could you please confim , if i can just use
GET : https://CMSIP:8443/api/v1/coSpaces/spaceID link form CMS and put the link in VLC to watch the stream (for users inside my network). with no need for Vbrik at all
if i should use vBrick DME server , shoud i order the User-Licence also for DME serveur or juste order the DME-Server suscribtion,
thanks in advance
11-05-2020 01:51 AM
I installed Wowza onprem server and got Youtube / Facebook streaming working. Thank you very much for the tip.
Had an issue where facebook feed doesn't work from the provided presets, but creating a generic RTMPS feed did the trick. Thanks again !
