CMS and LDAP
Chet Cronin
Level 4
Level 4
Hello ... I am running AcanoX3 with CMS 2.2.8 version
LDAP is sync complete
Problem:  Keep getting "The username or password you entered is incorrect."
1.  Verified my user name and password work logging into my local computer.
2.   I log into CMS Admin and AD and perform a successful SYNC per the log.
3.  Here is my config
Address:  Correct xxx.xxx.192.254
Port:  389
Secure Connection: "unchecked"
Username:     CN= "service account" Rest of path is good
Password:    Service account password good
Corporate Directory Settings:
Restrict search to searcher OU:   "checked"
Base Distinguished name:   (base domain name example:   DC=example etc.
Filter:   extensionattribute15=dc
Field Mapping Expressions
Display name:   $AMAccountName$
Username:  $AMAccountName$example.com
Spacename:  $AMAccountName$.cospace
SpaceURI user part:  $AMAccountName$.cospace
Space secondary user part:  Blank
Space call ID:  Blank
Any Ideas will help.
Thank you.
Chet Cronin
Patrick Pettit
HI Chet. Just throwing some stuff out here.
The filter you have is extensionattribute15=dc?  I don't see this in any of the mappings for the space or the users, but is this something that you need to filter on to pull your users?  Just curious is all.  If sAMAccountName is required perhaps try (sAMAccountName=*) as a filter perhaps?
Just making sure to, that under Status>Users, you have users there and you are logging in with the xmpp jid domain?  In your ldap setup you have $AMAccountName$example.com, its missing the @ symbol, but maybe thats a typo here?
Anyhow, you are running on port 389, so you can probably take a packet trace to see what the AD server is returning as it will send your common name to the AD server in a simple bind request to log in.  If you see something like: 80090308: LdapErr: DSID-0C090400, comment: AcceptSecurityContext error, data 52e, v1db1, result code invalidCredentials, then something may be wrong with the password.  If you see some sort of ldap referral being done, then maybe try the global catalog port of 3268.
But if you do, and you are filtering on extensionattribute15, make sure its part of the global catalog before proceeding.
