CMS Call to CUCM Fail
I'm facing an issue right now, when I try to make a call from CMS to CUCM it fail with this error
INFO : call 363: ending; local SIP teardown with reason 7 (transaction timeout - no provisional responses sending INVITE) - not connected after 0:32
I try to search what is the meaning of "reason 7" still no luck.
But when I make a call from CUCM (Jabber as my endpoint), call connected to space in CMS.
Anyone has any idea what could be wrong?
Thank You in advance
Jaime Valencia
Try configuring your outbound rule on CMS to unencrypted (assuming you're not using an encrypted deployment)
java
if this helps, please rate
Jaime Valencia
java
Hi Jaime,
My outbound rule changed to unencrypted and it works, previous configuration is auto.
Thank you for your help
