CMS Edge instead of Cisco Expressway for External WebRTC
Meddane
Recently I deployed a cluster of 6 call Bridges for three sites. Each site has two call bridges deployed.
Site 1 and Site 2 has the Cisco Expressway as Edge solution.
Site 3 does not have an EDGE solution. My question, can we deploy a CMS Edge solution for Site 3 as an alternative of the Cisco Expressway? since there is no need of additional licensing?
b.winter
Sure, why not? That is what the CMS edge components are there for.
8 Replies 8
b.winter
Meddane
Thanks for your confirmation. I will look a way to point the CMS edge to the local CMS only of the third site.
The connection is done in the callbridge via API, where you specify the TURN server.
Meddane
That ' s true and the webbridge located at the edge can be associated to the callbridge of site3 only
Correct.
as you have openend now a separate thread about your edge issues, is the question in this thread answered?
If yes, I would appriciate an accepted solution.
Hi @b.winter  I accepted your first comment as solution, and thanks for this rich discussion as always.
Hi, yes. Saw it already. TY. Just can return that compliment ':)'
