01-23-2023 10:19 AM
Recently I deployed a cluster of 6 call Bridges for three sites. Each site has two call bridges deployed.
Site 1 and Site 2 has the Cisco Expressway as Edge solution.
Site 3 does not have an EDGE solution. My question, can we deploy a CMS Edge solution for Site 3 as an alternative of the Cisco Expressway? since there is no need of additional licensing?
Solved! Go to Solution.
01-24-2023 12:04 AM
Sure, why not? That is what the CMS edge components are there for.
01-24-2023 12:04 AM
01-24-2023 12:13 AM
Thanks for your confirmation. I will look a way to point the CMS edge to the local CMS only of the third site.
01-24-2023 12:23 AM
The connection is done in the callbridge via API, where you specify the TURN server.
01-24-2023 12:52 AM
That ' s true and the webbridge located at the edge can be associated to the callbridge of site3 only
01-24-2023 05:22 AM
Correct.
01-25-2023 04:23 AM
as you have openend now a separate thread about your edge issues, is the question in this thread answered?
If yes, I would appriciate an accepted solution.
01-25-2023 05:08 AM
Hi @b.winter I accepted your first comment as solution, and thanks for this rich discussion as always.
01-25-2023 05:10 AM
Hi, yes. Saw it already. TY. Just can return that compliment ':)'
