CMS integrate with Polycom RMX 2000
Phuong Pham
I have 1 question about CMS intergrate with RMX 2000. From RMX 2000, i dial out to CMS and can connect CMS to room test on RMX. Can i call out from CMS to connect room test on RMX 2000 to a space on CMS? If can, how to do it?
Jaime Valencia
Yes, but you need to use the API to place calls from CMS.
EDIT: If the call is ongoing, you can also use CMM for this, I tested it the other day.
java
if this helps, please rate
Thank Valencia,
Could you guide me to user API for make call?
