CMS recorder error: certificate validate
jaheshkhan
Level 5
Level 5
cannot configure the recorder.
its a separate VM. only trying to configure recorder.
no webadmin
no callbridge
no xmpp
no webbridge. Only recorder in this VM nothing else.
i was trying to remove selfsigned certificate.
I generated CSR file.  created cer file with microsoft CA.
uploaded recorderCA.cer, ROOTCACert.cer and CallbridgeCA.cer in the root of recorder.
>recorder listen a:8443
>recorder cert recorderCA.key recorderCA.cer ROOTCACert.cer
>recorder trust CallbridgeCA.cer
>recorder nfs 172.17.55.18:/CMSREC
> recorder enable
But after this step it give failure. reason not a valid certificate
What could be the reason?
R0g22
Run the following please -
pki verify recorderCA.cer ROOTCACert.cer (this should return a "Success")
pki match recorderCA.key recorderCA.cer
for me this return no error
other one i dint try. ill try tomorrow.
