03-05-2018 01:13 AM - edited 03-18-2019 01:56 PM
Dear Colleagues,
During an CMS streaming configuration I have got an invalid interface error message.
>streamer listen a:445 lo:445 whitelist
Error: Invalid interface
I tried with different ports and interface with no success.
Have you faced one of you with this problem?
Laszlo
Solved! Go to Solution.
03-17-2018 10:33 AM - edited 03-17-2018 10:35 AM
As it turned out, there was a simple syntax error, I had to leave the whitelist term.
The proper command is:
Typical user error ;-)
03-05-2018 09:53 PM
03-05-2018 11:53 PM
Thanks for replying me.
Yes, I have tried to run the command with interface a and loopback separately and together as well... same error as I mentioned.
