CMS Web App - No Add Button for Space Template
We are currently running CMS 3.2.1. Users cannot see the add button for Space Template. Is there something we need to enable or configure on the API?
Sebastian Hughes
@Acevirgil de Ocampo  This feature was released in CMS 2.9. See the release notes for more information and steps on how to configure it. You can either do it all manually via the API (multiple API are required to be configured and they all then tie together to enable this feature), or you can use CMM to configure this feature. Hope this helps get you started, happy to answer any more questions you have.
Thanks Sebastian!
I'm seeing that in CMM is easier way to enable this feature. To do that, do we still need to integrate the CMM with LDAP? Currently the CMS is integrated with LDAP for user import but not CMM. We only use CMM for licensing the CMS server.
regards,
Ace
