CMS web bridge stop working after upgrade
Sandro Nardi
I have a CMS version 2.2.10 if I upgrade it to 2.3.1 the webbridge cannon register to the callbridge
Mar  8 17:50:45 user.warning cms2 host:server:  WARNING : web bridge link 1: get connection to cms2.collabora.lab timed out
Mar  8 17:50:46 daemon.info cms2 webbridge-reverse-proxy[1]:  2018/03/08 16:50:46 http: proxy error: dial tcp 203.0.113.2:54321: i/o timeout
Mar  8 17:50:53 daemon.info cms2 webbridge-reverse-proxy[1]:  2018/03/08 16:50:53 ERROR (WARN):failed to TCP connect to 203.0.113.2:54321: dial tcp 203.0.113.2:54321: getsockopt: connection timed out
Mar  8 17:51:05 user.info cms2 authp:  re-registration from server "cb.collabora.lab"
If I downgrade to 2.2.10 webbridge works fine
Did i miss some mandatoy step for the upgrade?
Hi Sandro,
we have the same problem! can you look into your logbundle.tar.gz if a file names sysdebug exist?
Have you solved these issue?
Can you ping the Chain Ruleset Section here please?
alamanso
Hello Sandro!
The 203.0.113.x subnet is used in both CMM and CMS as part of the docker interface, Its used for internal communication within the same box.
You could be facing the issue due to a configured static route that interfere with the docker, like : ipv4 a route add 0.0.0.0/0, remove such static routes, reboot the box and test again.
let me know if that helps!
