06-26-2018 04:24 AM - edited 03-18-2019 02:12 PM
So we are about to deploy CMS WebRTC over Expressway as people would like to use the Webbridge over Internet. We have the VCS-E with a single NIC and single CMS server with all the configurations in place. WebRTC internally is working fine. I checked the guide
And in the Configuration prerequisites it mentions "TCP Port 443 opened on Firewall from the public internet to the Expressway-E's public IP address". I am not a security expert, this is why I suspect that opening the port 443 to the Expressway's Public would be a probable risk as anyone from outside could access the Management interface of the CMS then. Is there any suggestion to either translate the port from 443 to any other port. If not then, what could be the solution for this?
Thanks for the feedback.
06-26-2018 07:03 AM
06-26-2018 07:13 AM - edited 06-26-2018 07:23 AM
Yes we have Web Bridge on 443 and WebAdmin on 445. The VCS-E Web Administration is using port 443. So currently what I am trying to do is ask the Firewall team is to open port 7443 or port 9000 for VCS-E Web Administration and port 443 for WebRTC. I think this should work.
06-26-2018 07:48 AM
06-27-2018 02:51 AM
Yes, this is what I was trying. I thought I found a way as in Expressway X8.10 I have the possibility to change the Administration port from 443 to either 7443 or 9000. But in case of VCS-E version X8.8.8, it is not possible to change the port as the port usage page states the port is not changeable. it's totally grayed out. Is this only due to the Software version? or is it because of the Advanced Networking option key?
We were also thinking to block the VCS-E admin sub-URL on the firewall and allow all other url's. Should this workaround also work?
Amit
