CMS with personal access code
akram.root
Level 4
Level 4
Hello all,
I need your help !
My customer ask me is that possible each external  user user can create a personal access code to access a space on CMS  ?
Best regards
Akram
b.winter
Hi Akram,
generally said, the access codes don't belong to users. They belong to spaces.
So, if you want different access codes for different users, you have to add as many as you want to the space and then give the codes to the users.
Sergey 1907
You can assign your own /api/v1/callLegProfiles to each participant in the space, or bind /api/v1/ callLegProfiles to /api/v1/coSpaces/<id>/accessMethods. It's well revealed here Configure and Troubleshoot Guest and Host Access on CMS Spaces
Meddane
