CMS
LSA4
Hi Team
I have never installed/quoted for a CMS solution.
Now i have been given a task to quote a CMS solution at our HQ with branches connecting.
What exactly will i need to get this working? CUCM, CMS, Expressway, conductor?
The datasheets/config/deployment guides just confuse me, and i cant find the ordering guide
Looking forward to ur assistance
Jaime Valencia
That completely depends on what you want to use CMS for, if you're a partner, you can reach out to pre-sales for assistance with a BOM.
If you're not a partner, reach out to a Cisco Partner with UC specializations to get assistance with the design and with that defined, what you need to buy.
java
if this helps, please rate
I am just looking to be pointed in the right direction.
The immediate need is for the HQ to host Video Calls, and presenation and the branch router will be connecting to the HQ
