Codec plus and HDMI passthrough / Call from laptop
Lars01
Hey
At work we have a Cisco Codec Plus and a Quad camera.
We mostly use MS Teams, and then I saw this video online:
https://www.youtube.com/watch?v=x5DQLGZ1oBs&t=686s
An admin can enable the function, connect a HDMI to a INOGINI device and audio from the Codec Plus HDMI output 2 + jack output and use it with your laptop.
I was wondering if you can add a features to the "Call from laptop" page:
Is it possible to add functions to this page?
What I'm looking for is three buttons. A button called "1", a button called "2" and a button called "3":
These buttons would control what comes out of the HDMI output 2 on the Codec Plus.
When you pres button "1" input 1 on the Codec will go out of output 2 on the Codec Plus.
When you pres button "2" input 2 on the Codec will go out of output 2 on the Codec Plus.
When you pres button "3" input 3 on the Codec will go out of output 2 on the Codec Plus.
Is this possible with this "switcher function"?
Perhaps with macros?
Best regards
Lars
The functionality above is implemented with the Macros and Room customisation - so it should be relatively easy to add your own buttons and functionality to it by editing what is provided.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
