12-27-2021 06:43 PM
What is the difference between;
Webex Codec Pro – No Radio No Crypto, CS-CODEC-PRO-NR-K7=, TTC6-13
abd
Webex Codec Pro – TAA, No Radio, CS-CODEC-PRO-NR++, TTC6-13
Solved! Go to Solution.
01-04-2022 07:02 PM
@Scott Nieto wrote:
Yes, so it appears there are seven different Codec Pro spares, right?
Not quite - there are 5 options of how to order a "new" unit (those that you listed).
Then, if you need to order a spare/replacement (to replace an existing codec), you would order one of the two "spares" versions and transfer the licencing from the old one to the new one.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-28-2021 11:55 AM
12-28-2021 04:43 PM
Thanks, but sorry that doesn't help. What is the difference between the spare and...
12-28-2021 11:55 PM - edited 12-28-2021 11:56 PM
AFAIK Webex Codec Pro – TAA, No Radio, CS-CODEC-PRO-NR++, TTC6-13 can only be ordered to a TAA Designated Countries. You can search google to find the list of countries which are included in TAA.
12-29-2021 05:50 PM
Yes, so they are both spares but only one is listed as a spare?
01-04-2022 06:00 PM
I believe the difference between the two that you are looking for is the first one doesn't come with Crypto (K7), but the second TAA compliant one does (K9).
01-04-2022 06:52 PM
There are five listed as non-options;
Webex Codec Pro - GPL, CS-CODEC-PRO+
Webex Codec Pro, No Radio – GPL, CS-CODEC-PRO-NR+
Webex Codec Pro – TAA, CS-CODEC-PRO++
Webex Codec Pro, No Radio, nonencrypted – GPL, CS-CODECPRO-NR-K7+
...and then two listed as spare options;
Webex Codec Pro, CS-CODEC-PRO=
01-04-2022 07:02 PM
01-04-2022 07:14 PM
That's interesting, thanks. But now that leads me to wonder how I would order a TAA compliant replacement for a Codec "Plus" when there is no spare TAA compliant codec listed for the Plus.
01-04-2022 08:44 PM
Only an issue if you have "TAA" devices that you need to worry about (thankfully I don't) - Ideally you'd have it under a service contract and just get a replacement through TAC.
01-04-2022 09:00 PM
Yes, I'm DOD, all TAA, we have a contract and it's not a problem. These days, it's not uncommon for contractors to suggest replacing SX80s with Codec Plus and then also buy the entire "spare" kits with cameras when we only need the codecs.
In my opinion, all SX80s should be replaced with Codec Pros.
