Compare CUCM 6.x , 7.x, 8.x
sameeralibaig
We are currently running CUCM 6.1.5. I proposed our organization to upgrade our system to 7.x or 8.x. But am asked the best and standard cliche question " Give some good reason to upgrade and we will do it" Can anybody justify the reason why to upgrade our system for 7.x or 8.x? I would be really thankful and i hope, it will be useful to many if anybody can give the brief comparison of features and merits of these Versions.
Thanks & God Bless you all..
Sameer
Table 1. New or Enhanced Features, by  Version
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps10662/sales_tool_c96-592658.html
BTW, this is the video over IP section.  You need to post the questions in the right section.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
6 Replies 6
carunach
CUCM Data Sheets are a good place to know about new features introduced in each version :
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/prod_software_versions_home.html
For example, SAF (Service Advertisement Framework), video phones and IME are some of the new capabilities introduced in 8.x
Arun
Arun has a great surgestion as a first place to look.  Some other quick things, 7.x supports E.164, 8.x has the features already mentioned plus built in phone VPN, and EMCC (Extension Mobility Cross Cluster).
That was very informative. Thanks Joe
Thanks Arun
java
java
The link isnt workibg for me... :-(
