02-12-2013 07:36 AM - edited 03-18-2019 12:34 AM
All,
I am trying to set a layout family via a conference template, not a specific layout. I see the pre-defined field for a specific layout & a layout ID, however there is no pre-defined layout family & ID fields. So I am ssuming I can put that in the Custom Parameters field, but I have no idea how to write a 'JSON' statement.... I am running XC2.0 btw.
Thank you,
Justin Ferello
Technical Support Specialist
KBZ, a Cisco Authorized Distributor
e/v: justin.ferello@kbz.com
02-12-2013 10:03 AM
Hi Justin,
I would say this is not directly possible, if you take a look at the mcu or the admin guide
then you will see that the family is either a MCU specifc setting (
'Home > Settings > Conferences' > Default view family) or something for the
endpoint config ('Home > Endpoints' / addressBookEntry.enumerat)
The parameters under the custom/advanced parameters field for the conference template
can most likely only use the confernce.create parameters, and there you just have the
customLayout which already exists in the list of pre defined parameters.
You should be able to add the family view for the auto-dialed Participants if this is an option for you.
So either specify the generic layout family for the whole mcu, use pre the pre dialed participants,
or file a feature request, I would go +1 on that as I also wondered about some of the "generic"
parameters which I would like to see in the conference specific configuration, ...
02-12-2013 10:05 AM
And about the syntax:
this should work if it would work (which it does not):
{"defaultLayout":"Family3","nextParameter":true}
