02-13-2023 11:12 PM
I am running CMS version 3.3 and trying to get WEBAPP working.
One thing I noticed reading the Configurating WEB APP CISCO guide is last page when I need to WEB into the CMS.
I go to Configuratio > General page.
I don't have the "External Access" Web Bridge URI window under the IVR inforamtion ?
I have the WEBBridge3 certs successfully installed I also have the c2w path correct in the API set.
Solved! Go to Solution.
02-13-2023 11:19 PM
everything is done via API.
- You need a new webbridge object, where you put the c2w url (which points to the webbridge component in CMS)
- Add a new empty webbridge profile
- In the new webbridge profile, add a new webBridgeAdress with the parameter "address" set to the meeting url (e.g. https://meeting.cisco.com)
- In the webbridge object, assign the webbridge profile
02-13-2023 11:19 PM
02-13-2023 11:39 PM
I am working off this document :
Only indicates configuring the webbridges object ? I entered c2w://bhrncms01.mcw.ad.usmc.smil.mil:9999 for the URL.
02-13-2023 11:49 PM - edited 02-14-2023 12:00 AM
But the first sentence says, for which version this doc applies:
How do expect it to be the same config then for a different version? You wrote, you have 3.3.
A lot has changed about how to configure CMS, especially in the last 2.9.x and first 3.x versions.
02-13-2023 11:59 PM - edited 02-14-2023 12:02 AM
When I was on the cisco site I only saw configure webbridge3 for version 3.0 so I assume it was good for version 3.3 ?
Do you have a link for the doc for version 3.3 ?
02-14-2023 12:08 AM
There aren't always config example or tech notes available for every version.
I don't have such a doc either, but you can always refer to the depyloment guide. There is one for every version.
02-14-2023 03:31 AM
Got it figured out ... thank you ...
Key was to make sure the certs were good and the fqdn was entered correctly
