Connect 3 camera's to C60
Shy Solenko
We like to coonect in chain 3 cameras to c60.
I saw in the PDF that the first one have to be ZOOM*12 and last one have to be Zoom*4, am i right?
and what about the middle one it can be zoom*4 or have to be zoom*12?
Thanks in advance.
Shy
Dharmesh Nandoria
Hi Shy,
PHD 12x camera is having RJ 11 port to connect next camera  in daisy chain, New 4x camers are not having RJ 11 port .
4x camera can be connect as a last camera in daisy chain .
In you case 1st & 2nd should be 12x camera and 3rd you can use 4x camera .
If you connect 4 camera in that case 4th can be 4x .
If you have old 4x camera which same in size of 12x and having RJ 11 port . It will also work as last camera as RJ 11 port is disabled in it .
hth
Kind regards,
Dharmmesh
Thanks..
I have old cameras x4 with RJ11... in this case can i use them in the middle?
Hi Shy,
You can not us in middle as RJ 11 port is blocked . it will be work as last camera .
hth
Kind regards,
Dharmmesh
Please rate replies and mark question as "answered" if applicable.
