Corona Virus Anti bacterial Cleaning touch 10 panels?
MicahHSN
With the threat of the Corona Virus all over... What does everyone recommend to wipe the Touch 10 screens down with in their Video conferencing rooms to make sure they are germ free?
Will a rung out Clorox or Lysol wipe work as long as its not super wet?
I know weird question... but tons of people use them everyday and i want to make sure they are clean without harming them.
Thanks again!
Ashish Patel
Unfortunately Cisco do not have any guidelines for disinfecting a Touch 10. For regular cleaning use a microfiber cloth or a soft damp clot.
>From my opinion any isopropyl alcohol/ disinfectant wipes while may be ok on the glass, but on the plastics, long term use may cause damage.
Suggest maybe using proximity to start calls from laptop or mobile device if possible, thereby reducing touches on touch 10 surface.
Having said that where do you stop? Lights, chairs, tables, door handles....
ashish
Response Signature
