cRTP for voip on internet
vinukondar
I am testing a voip between 2 sites connected via internet.
SiteA-------SiteA ISP--------INTERNET--------SiteB ISP-----------SiteB
I want to know if i can achieve rtp compression if enabled on site a and b routers?
else
does it needs to be enabled on all the routers between site A and B?
Thanks and Regards
Ravi
s-doyle
Level 3
Level 3
You must have RTP enabled through your backbone for voice quality to be guaranteed. Just enabling at the edge routers is not going to help you in this case.
asolis
Hi:
You can not do it, RTP compression have to be done every hop, and you do not have control over intenet.
