CTS-3010 - Background Image
Dean O'Meara
Hi.
Does anyone know if it is possible to change the background on a CTS-3010?
If so how would I go about doing this and what image format etc does the image need to be?
Thank you.
Alok Jaiswal
Hi Dean,
i believe you are asking gor image on the display right? i don't think its a possible option.
Alok
Hi Alok.
Yes, I am asking if it is possible to change the Display picture that is on the CTS screens when not in a call. I know this is possible with Codec like C20s etc however I were unsure if it is possible with the CTS-3010 units.
Regards.
Dean,
There's no option to change the background settings when the CTS endpoints aren't in a call. There is an option in 1.8 to remove the watermark however this does require a license.
JD King
Thanks all for your replies.
