05-30-2013 09:37 PM - edited 03-18-2019 01:12 AM
Hi Team
we have CTS 3010 system and while logging to the system via ssh found some days left for expiration.We had checked the setting from the CUCM side and found the admin password life to be zero.We even restarted the system the system twice after making the admin password life to be Zero still we have the same problem
Could you please help me in this
Tarun
05-30-2013 10:53 PM
Hi Tarun,
Please execute following commnad and see it help.
set upgrade firmware
utils system restart force
Kind regards,
Dharmmesh
05-30-2013 11:38 PM
Hi Dharmesh,
We had executed the above commands send by you still the problem is same.Please let me know what needs to do now.
Tarun Gupta
06-10-2013 04:09 AM
Hi Tarun,
I can see it's a very old post but I found it while searching the solution for a similar issue I faced recently with one of the CTS device ( was not using the default credentials).
Did you manage to sort this out ??
It looks like if we change the password from default to some other values, then we get this problem as I never see this warning for any CTS's set on default credentials. In my case, I revert the credentials to default which removed the warning message but on CUCM, the password life is set to 60 for all CTS's which I believe is again default value.
But still, if there is any other inputs, please let me know.
Cheers
Anjali
