CTS / CTMS Interoperability with CUCM 8.6(2a)SU1
ronaldo.gama
                   The CTS / CTMS version 1.8 are compatibles with CUCM 8.6(2a)SU1?
Ronaldo Gama
5 Replies 5
Hi Syed,
But the documment say 8.6(2a)SU2!!
Ronaldo Gama
Hello Ronaldo,
The 1.8 compatibility matrix is a great reference for the latest recommended code versions - 8.6(2a)SU2 is the recommended CUCM version.  There are some resolved caveats listed (BFCP comes to mind). Please reference the CUCM 8.6.(2a)SU2 release notes for further resolved caveats.
Thank you,
Paula Talamo
Hello Paula,
But the CUCM 8.6(2a)SU1 is compatible, right?
Ronaldo Gama
Hi Ronaldo,
CUCM 8.6(2a)SU1 is compatible with 1.8 but SU2 is recommended as it contains further bug fixes.   Some fixes to note in SU2:
  • CSCty04889: SessionBW low bandwidth behavior for BFCP-enabled SIP trunk
  • CSCtu16466: Make BFCP configurable for CTS endpoints via QED
Check the release notes for SU2 for the further list of resolved caveats:
http://www.cisco.com/web/software/282074295/93949/cucm-readme-862asu2.pdf
Thanks!
Paula Talamo
