01-22-2015 03:46 AM - edited 03-18-2019 03:55 AM
i have a touch screen model CTS-CTRL-DVC8 FREEZING when i connect to another VC unit it shows this message (lost connection with control device)
01-22-2015 04:39 PM
What device are you moving it from and to? How is it connected to the device (LAN, or direct connection). Have you unpaired it from the first device and re-paired it with the second device?
You can also try a factory reset on it. See: resetting-cisco-telepresence-touch-8-factory-defaults and then pair it with your chosen device.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
01-25-2015 11:03 PM
Touch screen had been removed from Tandberg Profile 52 C 40 ,i unpaired it and re-paired it again to the same device but no vain,also i paired it to EX 90 but the same result it keeps freezing ,i made factory resetting but also the touch is no working anymore and stuck into choose language.
