CTS-MAN meeting status No Show
jvodny
Is there any detail description in which circumstances we can have "No Show" status for the scheduled meetings on CTS-MAN instead of "Completed"?
P2P meeting - when Start Meeting button is pressed for meeting start than the meeting will be "Completed".
When the meeting will be done not using OBTP but manually (DN or Favortes) or the meeting will not realized then we wil have "No Show" status.
Is is correct please?
Multipoint meeting - for example 3 sites scheduled
What will be the result if one of the scheduled sites will not join the meeting?
Is the meeting status Completed if the call is connected via Multipoint device? It means only two sites where connected.
Please comment.
Josef
Johan Vermaelen
Hi Josef,
On P2P meetings, you're correct.
Regarding multipoint calls, I'm not entirely sure but think all scheduled rooms have to connect to the meeting before it will be marked as completed. Also keep in mind that for this to work, DNS resolution needs to work between the CTS-Manager and CTMS servers.
Hope that helps,
Johan
