03-12-2013
04:39 PM
- last edited on
03-25-2019
09:07 PM
by
ciscomoderator
I am trying to monitor the operational status of the IP Phone connected to a CTS-1300 through SNMP, however I found that the MIB (CISCO-TELEPRESENCE-MIB) related to this hardware does not specifically address this requirement.
As far as I could test, ctpPeripheralStatus (1.3.6.1.4.1.9.9.643.1.2.1.1.3) would only indicate the attached status but not the TelePresence-ready status, which in turn is somehow different from CallManager's point of view (registered/unregistered), since the phone could be registered to CUCM and in fact not OK to take calls.
Hence what I found from an empirical standpoint is that the ready status is achieved when the phone successfully downloads and installs the MIDlet, that in turn being reflected when polling the MIB retrieving ctpPeripheralDescription (1.3.6.1.4.1.9.9.643.1.2.1.1.2):
iso.3.6.1.4.1.9.9.643.1.2.1.1.2.2 = STRING: "IP_PHONE -- MACAddress=AABBCCDDEE,HostName=SEPAABBCCDDEE,PhoneDN=1000,AppLoadID=jar75sip.9-2-1TH1-13.sbn,
BootLoadID=tnp75.8-3-4-16BN01.bin,Version=SIP75.921S,HardwareRevision=11.0,
SerialNumber=ABC12345XYZ,ModelNumber=CP-7975G,MidletVersion=TSPM-1.8.1-P1-1S"
ctpPeripheralStatus
iso.3.6.1.4.1.9.9.643.1.2.1.1.3.2 = INTEGER: 0
CtpPeripheralStatusCode ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"The textual convention identifies the peripheral status.
noError (0) --
Expected peripheral device is functioning through
the attached port.
ctpPeripheralDeviceCategory
iso.3.6.1.4.1.9.9.643.1.2.1.1.4.2 = INTEGER: 3
CtpPeripheralDeviceCategoryCode ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"The textual convention identifies the peripheral type.
unknown (0) -- Unknown Device
other (1) -- None of the listed device
uplinkDevice (2) -- Device attached to CTS uplink port
ipPhone (3) -- IP phone
If ctpPeripheralDescription show the phone's software listed then it is good. Perhaps the OK/Not OK Status as seen through CTS GUI is displayed after an evaluation of this sort?
I've asked around and did some further testing along but apparently this is the only way to assert correctly via plain SNMP, whether or not the phone is functioning properly.
Would there be any other way to check this?
Thanks in advance,
Gabriel
Solved! Go to Solution.
03-20-2013 01:55 PM
Hello Gabriel,
Since you haven't received an answer yet, I am scanning my memory archives and what you have concluded matches what is in the MIBs, RFCs, and SNMP Trap Message doc for CTS Systems:
The displayed phone load, midlet version and the noError(0) status of the ipPhone (3) should coincide with no errors in the GUI and the phone successfully showing the midlets and being TelePresence-ready.
HTH,
Paula
03-20-2013 01:55 PM
Hello Gabriel,
HTH,
Paula
04-04-2013 10:53 AM
Hello Paula,
Thank you very much for your reply!
Couldn't find the information in a compact form in the beginning but your answer is definitively what I was looking for.
Thanks once again.
Gabriel
