CUCM and SRST Lab
doroteo77
I'm trying to setup up a very basic lab to show CUCM 8.5 with an SRST 2900 series router.  I don't need an advanced configuration.  Can someone point me to some documentation on how to setup the SRST router?  The router is still in the box.  The only thing I need to use the router for is SRST so I don't need advanced routing.
Thank you.
5 Replies 5
Thanks Adrian.  This is a good start.  Do you have any information on the router setup?  In other words, do I just follow the initial router setup that is in the 2900 series documentation and then add the SRST config?
2900 Series Installation:
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/Hardware_Installation_Guide.html
Yes, do the initial basic setup and then add SRST configuration. Just in case, in order to have VoIP/IPTelephony in ISR G2, your router must be UC technology packaged. More about IOS in ISR G2:http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html#wp9000793
Hope it helps.
- Adrian.
Hi Adrian,
Thank you for all the help.  Do you know if there's a way to obtain a non-production UC license?  I saw that I can request a trial license for 60 days - but is there a way to get something more permanent for a lab / testing environment?
You should contact Cisco TAC and explain them your needs to see if they can issue you an extension for longer trials.
Support Cisco Worldwide Contacts:
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html#telephone
Good luck!
- Adrian.
