customize VCS warnings
Louis-Alex
Is there a way to customize my VCS alarms ?...
I mean, configure what should and should not be thrown as warning ?
Patrick Sparkman
As Mohammed pointed out, there is no way to alter VCS alarms in anyway, even if you don't want to get an alarm for something you deem not important.  To get an idea of what types of alarms the VCS might alert you to, refer to the VCS Admin Guides, there is a section on managing alarms.
Mohammed Khan
VCS alarms are system defined cannot add or modify them.
Patrick Sparkman
