Dial the IPVC IVR
jdrohen
I’m trying to dial my IPVC IVR from a IP phone. I have set up H.225 trunk in CCM and a route pattern to point to that trunk. I created a static e.164 address on the gatekeeper to point to the IVR. When I dial the IVR from a phone “IVR Application” shows up on the phone but disconnects immediately. I have done the same process with my MCU and when I dial the pattern it drops me into an ad-hoc conference. I need the users to be able to dial the IVR and enter a conference ID. Does anyone know what steps I’m missing?
Jesse
gatekeeper
zone local CTSF3745 10.0.0.19
alias static 10.0.0.25 1620 gkid CTSF3745 terminal ras 10.0.0.25 1619 e164 620
gw-type-prefix 1#* default-technology
no use-proxy CTSF3745 default inbound-to terminal
no use-proxy CTSF3745 default outbound-from terminal
no shutdown
CTSF3745#sh gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
10.0.0.19 1720 10.0.0.19 1719 CTSF3745 MCU
H323-ID: IPVC3540
E164-ID: 610
E164-ID: 80
E164-ID: 81
E164-ID: 82
E164-ID: 83
E164-ID: 84
E164-ID: 85
E164-ID: 86
E164-ID: 87
E164-ID: 881
E164-ID: 882
E164-ID: 887
E164-ID: 888
E164-ID: 889
E164-ID: 89
10.0.0.25 1820 10.0.0.25 1719 CTSF3745 H320-GW
H323-ID: RV-GW-172024054241
Voice Capacity Max.= Avail.= Current.= 0
10.0.0.25 1620 10.0.0.25 1619 CTSF3745 TERM S
H323-ID: CTSFIVR
E164-ID: 620 (static)
10.0.0.100 56228 10.0.0.100 49424 CTSF3745 VOIP-GW
H323-ID: TRUNK_IPVC_1
10.0.0.101 60430 10.0.0.101 50010 CTSF3745 VOIP-GW
H323-ID: TRUNK_IPVC_2
150.114.144.101 1720 150.114.144.101 17300 CTSF3745 TERM
E164-ID: 12545327066
H323-ID: IPOWER9000
Total number of active registrations = 6
andreas.plaul
Hello Jesse,
I am running into the same problem. Apart from having the same setup, the only difference is that if I call the IVR the call is not dropped, but I hear nothing from the IVR.
So my question is if you have solved your problem ??
Best regards,
Andreas
