Bookmark
Subscribe
251
DIALING OUT VIA INTERNET
Chet Cronin
Level 4
Level 4
Running an C40 and trying to dial both the Polycom and CISCO test numbers via IP only (No gatekeeper)
In direct mode.
Getting the following error:
Could not place to h.323 64.102.241.236 (which is the CISCO test number)
Any ideas ... There is a firewall in the network.
Verified ports and 1719/1720 are open bi directional
VR
Chet
Chet Cronin
Hi Chet,
Check ALG on your firewall. Disable ALG for H323.
Also refer to these list of ports for H323  standalone (direct):
Try this settings on the codec:
Configuration->Advance Configuration->H323->Profile 1->Callsetup Mode: Direct
Configuration->Advance Configuration->H323->Profile 1->PortAllocation : Static
Enable NAT mode on the codec:
Configuration->Advance Configuration->H323->NAT->Address : YOUR_NAT_ADDRESS
Configuration->Advance Configuration->H323->NAT->Mode: ON (Try also set to Auto if ON won’t work)
Acevirgil
